Excel Easy Title.vi can't run
My new report and Excel Easy Title.vi can't run when i click run icon, it's
(1,974 Views)
It seems like you don't have NI Report Generation Toolkit installed.
(1,972 Views)
where can download the NI report generation toolkit?
I can find the vi in vi.lib
(1,959 Views)
Are you using Labview 64 bit version?
(1,952 Views)
MS Office (Excel and/or Word) must also be installed on the computer for the corresponding NI Report Generation Toolkit to work
=== Engineer Ambiguously ===
(1,922 Views)
Yes, I installed the word and excel, my labveiw is 32bit 2018 version
(1,879 Views)
Keep in mind, that the Report Generation Toolkit is something that you need to buy if you are not using the professional development suite of LabVIEW.
Also keep in mind that you should install MS office in the same bitness as LabVIEW. Calling ActiveX-properties and methods otherwise is quite difficult up to impossible.
Regards, Jens
Kudos are welcome...
(1,875 Views)
