Excel Graphs using Office Report Generation
I'm using Office Report Generation and I would like to add a grpah to my excel spreadsheet using existing excel spread sheet data.
Right now the only way I can add a grpah is to load the data into labview and create a graph in a 2d array.  However that way the graph has no linkage to the data in the exc el spreadsheet.  I can't use a template to create the graph then load the data because different results require different methods.  However if I could modify an existing graph within labview I could use the template but I can't index a now labview created graph.
Can anyone suggest anything?
(2,814 Views)
Thanks for posting to the NI Discussion Forums!  I think you might be right, and there might not be a conventional way to create your graph from the Report Toolkit (after all this is designed more to create a report from known and unchanging data that you can move to excel for demo purposes).  There might be some other ways to do this.
My first recommendation if you would like to stick with the Report Gen. VIs, you can design an Excel Macro to generate a graph from the spreadsheet.  LabVIEW can execute the Excel Macro through the Report VIs (see the Report Generation->Excel Specific->Excel Advanced->Excel Macros palette).  There are some good examples and documentation out there about calling Excel Macros:
http://venus.ni.com/stage/we/niepd_web_display.DISPLAY_EPD4?p_answer=&p_guid=B45EACE3DD2F56A4E034080020E74861&p_node=DZ53040&p_rank=&p_source=Internal&p_submitted=N
http://venus.ni.com/stage/we/niepd_web_display.DISPLAY_EPD4?p_answer=&p_guid=B45EACE3D9D856A4E034080020E74861&p_node=DZ53003&p_rank=&p_source=Internal&p_submitted=N
http://venus.ni.com/stage/we/niepd_web_display.DISPLAY_EPD4?p_answer=&p_guid=B45EACE3DC6D56A4E034080020E74861&p_node=DZ53003&p_rank=&p_source=Internal&p_submitted=N
http://zone.ni.com/reference/en-XX/manuals/323805A-01/RepGenUG_07/
If you do not want to use the macros, you might have more luck using ActiveX, or other means in which to interface with Excel than are provided in the Report Generation Toolkit.  There are countless examples and discussions about Excel, LabVIEW and ActiveX so I won't spend too much time here on it, but if you think you might want to use this as an option, let us know and I can see about finding some examples on it for you.
Hopefully this helps!  Please let us know how things go.
Travis M
LabVIEW R&D
(2,796 Views)
