Solver is an AddIn that is not installed in a typical Excel installation. If you attempt to run it from the menu, it will prompt that it needs to be installed. This could be what is causing this error. Run the Solver from the menu and check that it is able to run manually.
After that, check the parameters carefully to make sure that you are not giving the Solver a bad cell reference or an invalid parameter.
Michael Munroe
www.abcdef.biz
