Excel Read
I want to read  density from excel file depanding on the value of temperature. Please tell me how to start with this.
Message 1 of 10
(7,524 Views)
If i am not clear,
Say temperature is 27.2 i need to read 27th row and 2nd column..
Message 2 of 10
(7,521 Views)
Hi kaush,
I suggest you to read this thread for more about Excel.
- Partha ( CLD until Oct 2027 🙂 )
Message 3 of 10
(7,506 Views)
As Parthabe suggested, reading the Excel Board thread will be a good starting point.  You'll need to use Active-X to communicate with the Excel Application to read your data.
R
Message 4 of 10
(7,493 Views)
Accepted by topic author kaush
Here is the job done...
Message 5 of 10
(7,482 Views)
Can somebody transfer the krsone's file to compatible with labview 8,5? Thank you.
Message 6 of 10
(7,309 Views)
Hi pesonen,
Message 7 of 10
(7,294 Views)
Thank you very much kaush.
Message 8 of 10
(7,266 Views)
Can somebody transfer the krsone's file to compatible with labview 8,2? Thank you.
Message 9 of 10
(7,237 Views)
hi
i want to simulate a dashbord with labview interface
i did this one but my problem is to read data of simulation from excel file the one that i did it the simulation is based on while loop and other structure
 please can you help i realy need it
Message 10 of 10
(5,638 Views)
