Excel Report Generation
Hi
I have to generate an excel report which should first read from previous excel file and then generate a grah on a new file having data and graph. Infact I have implemented this part by modifying Labview example. But I could'nt understand where should I specify my x-axis and y-axis columns. My data is like this
Time            Ch1                Ch2              Ch3
1:1:2           1                     2                  3
1:1:3            1                     2                  3
1:1:4            1                     2                  3
I have to generate graph with time on X-axis and channels on y-axis.  SO there will be three lines for ch1,2,3 against time axis.
(3,298 Views)
hi mimran,
  please look at this attachment...
Thanks and regards,
srikrishnaNF
Srikrishna
(3,284 Views)
Did I get it right, you want to read excel data and graph the same data in excel  by using LabVIEW?
Or read some excel data, do some LabVIEW and report the result to a excel graph?
Even if I'm addicted to LV and hate VBA,  for the first case just turn on the macro recorder , hit alt-F11 do some minor changes and your done.
Greetings from Germany
Henrik
LV since v3.1
(3,279 Views)
HI Henrik
I have to read excel data and graph the same data in excel  using LabVIEW generation toolkit.
(3,271 Views)
