Excel Report Generator Error
I have a test application that uses MS Excel Report toolkit to print the test results using a custom template file. When I try to print the test results I get the following error -2146959355 (see attached picture). Any idea what triggers this? It seems that is generated by Excel Active X control. I also attach the Vi I use to print the test results as well as the templates
Thank You
Nick
(2,856 Views)
Accepted by topic author Nikko1
look at this
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P82QSAS&l=en-US
http://digital.ni.com/public.nsf/allkb/83211E3A088D0C3786256DB700621FE8
(2,839 Views)
