Excel Report
Hello.  I have 3 VIs which make 3 excel reports. They work independently. I would like to know if I can write the 3 reports in only one Excel file (in separated sheets). I have try it but when I save the file, Labview overwrite the 3 sheets, not only the sheet where I generate the report.
Thank you.
(4,340 Views)
Have a look at the excel board in the breakpoint area. There are some vi's in there that will help you. You have to set the active workbook and then save it.
Joe.
"NOTHING IS EVER EASY"
(4,330 Views)
The attached example may help.
Scott.
(4,330 Views)
This will only work if you have the addon toolkit, the vi's in the other thread do not require the toolkit, they all use active X.
Joe.
(4,329 Views)
Thanks for repply!!
I have the toolkit, but I want is: open VI1-save report in worksheet1-closeVI1, open VI2-save report in worksheet2-closeVI2, open VI3-save report in worksheet3-closeVI3.  I have seen the activeX VIs, but I can't find one which solve my problem.
(4,323 Views)
if you connect the Excel file path to template input parameter of New Report.vi, you will be able to obtain what you want.
I hope this helps.
crisR
(4,245 Views)
Thanks for reply!
It seems a good solution.
(4,211 Views)
