Excel data write using report generation vi's
I can read data from an excel sheet but can not figure a way to write data to specific cells using the LabView report generation vi's.
(2,889 Views)
In the "Excel Easy Table" VI you can specify where you want a table to be placed by wiring a value to the 'Start (0,0)' input. If you want more control than that you will have to open the "Excel_Insert_Table" vi and modify it. It is located in the _exclsub.llb library. I highly recommend making a backup copy of this llb before modifying any VI's in it.
Chris_Mitchell
Product Development Engineer
Certified LabVIEW Architect
(2,889 Views)
