Excel file not created while running application using executable on different PC
I have created an executable and an installer for an application. In this application I am saving data to an excel file using a template. This works fine when I run using the executable on development PC. However when I deploy this application on another PC, excel application opens the template and writes the data but the file is not saved or created at the desired destination.
The path for file to be saved is coming up right but no file is saved.
Development Machine details:
OS: Windows 7
Office version: 2010 (but I am saving file in 97-2003 format)
LV version: 2012
I had checked 'Unlock' option while building the application but stil faced the same issue
Message 1 of 1
(2,610 Views)
