Excel file not reading correctly
I am trying to run the Main vi but i am not getting the results i want. In the conduction velocity vi i have a read from spreadsheet vi to read an excel file. The excel file is a 9x9 matrix. When the spreadsheet vi reads it it is a 47x5 matrix now. Why is this?
(4,245 Views)
Hi reggie,
FAIL! 😄
Do you know the difference between a spreadsheet file and an "Excel" file?
You use ReadFromSpreadsheetFile to load an Excel file: this will not work for files in proprietary MS-Excel file format (like your XLSX file)!
Spreadsheets are just text files using delimiter chars to separate elements in a table.
The LabVIEW help explains all this pretty clear - did you read it? The help for this function starts with "Reads … from a numeric text file"…
(4,233 Views)
Oh alright thanks for the information.
(4,218 Views)
The Good News, however, is that since you have LabVIEW 2014, the Report Generation Toolkit is included, and that does a really fine job of reading Excel files, even the (newer) .xlsx format.
Bob Schor
(4,197 Views)
Yes, you can use the report generation toolkit. You have to (unintuitively) open a new report with your Excel file as the template.
(4,160 Views)
