Excel footer
Is it possible to insert a footer at the bottom of each sheet of an Excel workbook using the Report Generation Toolkit?  Thanks.
(5,194 Views)
There is a VI called Excel Set Page Numbering that writes to the footer.  You could modify that if you want more than page numbers put into it.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(5,176 Views)
I was curious about Set Page Number, so I took a look.  Turns out the code seems specific for Word 2007, and gets "down and dirty" with ActiveX.  I've never used Excel footers, so have no idea if this particular function (from the Excel-Specific Palette, but seemingly internally calling Word functionality, which, given Microsoft, might be just fine) works or not, but I'd be reluctant to mess with it ...
Bob "Niwa Tori" Schor (that's "chicken" in Japanese)
(5,162 Views)
Accepted by topic author AT1
I found what I was looking for - Set Report Footer Text.vi from the Report Layout pallet.
(5,140 Views)
Oh Yeah, I went right for the Excel specific VIs and forgot about the Advanced Report pallete.  Glad you found what you needed.  Smiley Happy
(5,117 Views)
