Excel: how to get last row value for two columns
Hello there,
I am working on application where I need to make an excel file which has two columns, one for PASS UUTs and another for FAIL UUTs. For each result of test, i need to make an entry of unit's serial no. in respective columns.
I am using report generation tool-kit which has a function to get last row. However, it is returning value of 'bigger/longer' column. So, can i get last value for each particular column?
Attached is the excel file for reference.
Manan
(2,754 Views)
Accepted by topic author Manan@MM
Hi Manan,
read the sheet until "last row", then search for empty cells (aka elements) in those 2 columns…
(2,746 Views)
