Excel power tool using Labview???
I want to compare column A of Excel spreadsheet 1 to Excel spreadsheet 2 column A and if there is a match turn the data RED in those matching cells. Please Help?
Rico Bravo
(2,740 Views)
I think the easiest way to do this is to simply set up conditional formatting directly in Excel, rather than resorting to using ActiveX to control Excel from LabVIEW, which is what you'd need to do.
(2,732 Views)
