Excel report ActiveX missing methods
Yes I agree with Eric. I also made the registry changes so the ActiveX methods did not disappear every time I started LV.
Message 11 of 14
(1,546 Views)
Good news!!!
I just noticed that after a reboot things are broken again.. you think that this could happens also distributing the compiled VI (.exe) ?
I.e. I need to fix the registry also on the target machine?
Message 12 of 14
(1,540 Views)
I never noticed anything wrong when I distributed/ran the EXE on other machines. Wouldn't hurt to look.
Message 13 of 14
(1,526 Views)
Even if you don't fix the registry, VIs that use the Excel methods with work correctly. You just can't edit them since the methods will be empty when selecting the drop down. I have an executable that writes to Excel and I didn't change the registry so it'll be OK.
Message 14 of 14
(1,518 Views)
