Excel save as
Hello forum'ers,
I'm stuck with this simple function i'm looking for - Excel "Save as". Ive already search the related topics and use the "save as" of workbook invoke node but error 97 occurs. i believe there is something wrong in my code. anyone there kindly help me identify the problem.
Situation: I have an Excel file named "book1.xls" - open it - append text - save as "new1.xls" - close.
Desired Result: maintain my book1.xls unchange, generate another file "new1.xls.
I attached a draft example to pinpoint my problem.  Im using LV 8.5
thanks for attention - Kung Hei Fat Choi!...
Ivel R. | CLAD
(5,145 Views)
Hi, you need save file after you create a New Report, at this moment the file book1.xls doesn't exists.
(5,139 Views)
to bruno,
sorry for delayed reply (we have a long holiday here in Taiwan). In response, the book1.xls was existed. what is not is the new1.xls.
what i want to do is to open the existing book1.xls, -- changed some data, -- save to another file name new1.xls like we have commonly did in excel application "save as function". so that book1.xls will not change and create another file named new1.xls. i hope my problem is more clear now.
i think what you want to say is that the "new1.xls" was not existed and i need to create this 1st? if so, then how does the invoke node "save as function" works? it looks like it does'nt work the same as excel function. because we knew in excel we just need to select the "save as" and create a new name - then new file was created!..
regards,
Ivel R. | CLAD
(5,099 Views)
Accepted by topic author ivelson
Have you tried the 'Save Report to File.vi' in the Report Generation palette?  I haven't, but it sounds promising...
(5,092 Views)
to Darin,
yeah... that was truly promising because it works!...
thanks a lot!
Ivel R. | CLAD
(5,087 Views)
Kudos,
Can you save your LabView program in 8.2 and repost it? I would like to take a look at your code.
(4,927 Views)
Save Report to File does work for creating a new excel workbook, what is confusing is the description [even in LV2019] reads " Saves HTML..." which does not make you think it would save an .xls.
(3,549 Views)
