10-23-2008 07:38 AM
Sure!
This is an Excel ".csv" file (comma delimited) with 2 columns:
Time (seconds) and randomly generated setpoints (mmH2O in our case ).
10-23-2008 07:39 AM
bmann2000,
No, I have not. But will try.
Thanks for your reply!
10-23-2008 08:12 AM
Hi Perillo_U...,
the attached example should work for you.
If not, can you upload you vi?
Mike
10-23-2008 09:45 AM
Hello Mike,
No, I am having the same problem and attached the VI for you.
Thanks Mike!
10-24-2008 01:42 PM
Hello bmann2000,
The problem really isn't reading the data, but reading in an appropriate fashion to make it match the structure needed to feed the PID Setpint Profile SubVI.
10-28-2008 12:29 PM
To help clarify, I am posting a copy of the PID Setpoint Profile VI. Maybe this will help some.
Thanks!
10-29-2008 09:53 AM
Hi Perillo,
I took a look at your VI and it looks like you are inputting the correct data type. What type of error are you getting?
Justin P
10-29-2008 10:38 AM
Hello Justin, thanks for your interest.
Well, apparently it reads all data from spreadsheet at once instead of sequentially, so a few seconds later I got either a "zero" value or "NaN". This VI is actually a SubVI used in a control VI.
10-29-2008 11:14 AM
Does the second Setpoint Profile VI with the constant wired into it read the values sequentially?
Justin
10-29-2008 11:26 AM
