Excel toolkit --excel save.vi is broken arrow
After installing the Goop toolkit and excel toolkit . I found that the "excel save.vi" having broken arrow and give me an error.
(2,868 Views)
Ok, first -- do you have excel installed? Sorry, had to ask.
It seems a little odd that you say the vi has a broken arrow and also gives
you an error message. Does that mean that the vi will try to run even
though it has a broken arrow but then it gives an error message, or do you
mean that even without running it it gives an error message?
I once had a vi with a broken arrow but no error in the error list window.
I clicked the box to show warnings and it turned out that it was a warning
that caused the broken arrow.
"YCHENG" wrote in message
news:50650000000800000042620000-1031838699000@exchange.ni.com...
(2,868 Views)
Yes, i am running Excel 97.
Before modification the "excel save.vi" , it has a broken arrow so cannot run and the error list is " Invoke Node : contain unwired or bad terminal" .
After I changed the Invoke Node, (Just created control for all the input) ,then no broken arrow but after running giving the error message that i attached in previous message.
Hope you guys can help.
Thanks.
(2,868 Views)
