Excel with Labview
hi every bady,
Any one can tell me how can I import an excel file to LabVIEW 8.6 ??  I need to read it and make some treatements on it on LabVIEW !
(3,806 Views)
Do you mean read excel? What do you mean by treatments? Smiley Very Happy
You can use report generation toolkit or ActiveX for accessing Excel in LabVIEW.
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(3,805 Views)
Tkx for your replay,
Yes, at first, I want to read an excel file in LabView.
By treatements i mean, some operations such us (make calculations and draw graphs...) !
(3,802 Views)
Accepted by topic author za3im_ensa
You have two options.
1. Use Report generation toolkit and easily play with the excel.
2. Use ActiveX and access the MS Office Excel and do whatever you wanted to do.
(3,791 Views)
If you  are going to try the Active X path see this board for examples.
http://forums.ni.com/t5/BreakPoint/Excel-Board/m-p/379682/message-uid/379682#U379682
Tim
GHSP
(3,788 Views)
