Excel
How to enter data in excel at a specific location.
Suppose a VI stores its result in excel from Row 0 column 0 to Row 4 coulmn 4
The next VI stores its result in excel from Row 7 coumn 0 to Row 11 column 4.
And So on. Which Function I can use.
Please Help Smiley Embarassed
Message 1 of 15
(3,984 Views)
You can use the "Excel Easy Text.vi" for writing data into specific location.
Message 2 of 15
(3,980 Views)
Can we enter the data to Excel Easy Text.vi from 3 numeric controllers?
Message 3 of 15
(3,975 Views)
For that I would have to convert the data.
So any other option?
Message 4 of 15
(3,954 Views)
That is a straight forward way of writing the data to the excel. Do you want to generate only the excel sheet or just a file that can be viewed using Excel?
Message 5 of 15
(3,937 Views)
I want to generate an Excel sheet. I may also write in that excel sheet.
Its like the results from different experiments will be stored into the excel sheet. But I want to allocate different space for each experiment.
Message 6 of 15
(3,934 Views)
Please do not create multiple posts. People don't know what has already been discussed. In fact, P Anand's suggestion of using the Report Generation Toolkit was already discussed in the other thread.
Keep the discussion in ONE place!
Message 7 of 15
(3,916 Views)
You can create a new sheet with Active X. Write data to it, too.
"Excel Macro Example" has a few Active X functions in subroutines you could take a look to get started.
Mariana.
Message 8 of 15
(3,914 Views)
Folks, this has already been discussed in the original thread. In fact, I told the user EXACTLY what function to use.
Please keep your responses there.
Message 9 of 15
(3,912 Views)
Good Catch smercurio_fc. As said please hold a single thread for your queries and this is missing in the Posting Etiquette.
Message 10 of 15
(3,911 Views)
