Excellent custom icon editor
does anybody know if it will be a new version for LabVIEW 8.6??
I'm using LV8.6 and I miss this wonderful icon editor. Smiley Sad
Tweety
Message 41 of 52
(4,458 Views)
Tweety,
sorry but I have never used the IE in LabVIEW 8.6
I am pretty sure that it does work if you change the install.vi a bit. Open this VI and change the constant that is wired to the big for loop from 2 to 1.
If it only runs once, the BD of the VIs is not removed.
Tom
Message 42 of 52
(4,458 Views)
Tom,
thanks for your very fast response.
I'll check it out if it works.
Apart from that, I guess to remeber that you had advised the version 3.0 at the download page.
Are you working on it or rather not?
Tweety
Message 43 of 52
(4,450 Views)
that is right, but somewhere down the road something happened to version 3.0...
The question might be answered if you register for the new LabVIEW beta program:
Beta Program Resource Center
Tom
Message 44 of 52
(4,448 Views)
The icon editor is running. Now I can restart to paint great icons. 🙂
But a the first two trials to install the icon editor LabVIEW crashed.
The third time I run the VI with the single step functions to find out where the problem is.
I don't know why, but in this case no problem occured.
Anyway, thanks for your support.
Tweety
Message 45 of 52
(4,425 Views)
Hi ThSa,
where is the IconEditor gone?
The links in this thread just result in error messages and searching for "advanced icon editor" on the community zone doesn't get any results too...
Message 46 of 52
(4,262 Views)
That is a really good question.
I guess it was my fault a couple days ago (how else could it be possible). I was about to update the source code, when the screen of my lap top refused to display anything. I clicked several times around because I thought it just hangs. It seems that I hit the delete button because I can't find the IE in the repository either.
Here is V2.2 in LV 8.6
Message 47 of 52
(4,232 Views)
According to the comments about my suggestion, I'm expecting LV 2009 to ship with an improved icon editor. May be it is based on ThSa's one ! Let's wait some weeks...
Message 48 of 52
(4,187 Views)
Probably...Maybe...
If the case may be, the UI and handling of the IE would be completely different than V2.2
Message 49 of 52
(4,157 Views)
Hi, i'm using the version for labview 8.5.1, but the setting tab is always disabled. seems like it can't get a valid reference to the VI.
is there anyway I can fix it?
sorry but i don't have the original installation files anymore and it is no where to be found anymore.  it now only has the "Enhanced Icon Editor for labview 2009", unfortunately we don't have any plans using labview 2009 yet.
I watched the video and it is really nice.  can it be ported to labview 8.5 or 8.6?
thanks
Message 50 of 52
(3,891 Views)
