Exception: Access violation (0xC0000005) at EIP=0x00D98189
Anyone else plagued by this? I can not even save a VI without getting this error.
LabView 2013 (32bit) Windows 7 Profesional (64bit)
=== Engineer Ambiguously ===
(5,633 Views)
I just had to give up on recovering the vi and lose several hours of work.
I guess for LabView 2013 save early and save often
(5,629 Views)
Check out this discussion on Stack Overflow -
http://stackoverflow.com/questions/5303524/what-exactly-is-the-scope-of-access-violation-0xc0000005
It seems this error occurs whenever your program "tries to read memory that isn't mapped. Followed by trying to execute a machine code instruction that isn't valid or can only be executed by privileged code."
Hope this helps.
Kelsey W.
(5,580 Views)
Yes, I undestand what an access violation is, but it is not my program that is causing it.
I was getting the error when simply placing a vi on the block diagram or attempting to save my work.
(5,561 Views)
Sorry, when I said "your" program, I meant LabVIEW. Not necessarily your VI.
With that said, what does your VI do? Are you writing to arrays anywhere or accessing files in memory? You can post a screenshot of your VI if you'd like.
Additionally, please post the error/crash repot.
Kelsey W.
(5,535 Views)
