ExceptionCode: 0xC0000005
Hello Everybody,
I, meaning an operator, ran into this problem with an access violation.  The program ran fine on my windows 7 machine, and it seemed to run fine on their windows 7 machine as well. I am using some NI hardware: USB-8451 (I2C), and the USB-6002. I have a feeling that the USB-8451 is where the issue might be.  Could this be a driver issue?
(5,871 Views)
Hard to say. Seeing some code would be helpful. Also when does the problem occur?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(5,863 Views)
Also, does this error occur when running a VI or an executable?
A Johnson
(5,819 Views)
It only appears in the executeable, and I have not been able to reproduce the problem over here. I wonder if this was a fluke.
(5,791 Views)
Super hard to say. The lvlog.txt just lists the error as an access violation (LabVIEW wrote where it wasn't supposed to) and the last thing that LabVIEW was trying to do, according to the dump, was allocate a small amount of memory. If you are able to get some sort of reproducing case, I would probably just call NI support at 866-275-6964.
(5,776 Views)
 I was afraid that was the case. Thanks for looking into it. Smiley Happy
(5,739 Views)
