Exctract from an A2L database all the parameters of a specific measurement
Hello the forum,
I'm working on a A2L database using the ECUMC toolkit. In particular, I need to extract all the parameters of few measurements and, to accomplish this task, I use the code shown in the attached image "LabVIEW A2L parameters" (the code is tested and fully working).
I want to extract one other parameter that belong to the same measurement, called "DISPLAY_IDENTIFIER" (see image "A2L measurement example"), but I can't figure out how to do this, considering that the only parameters that can be extracted are the ones shown in the attached image "ECUMC measurement parameters".
Can someone help me with this?
Thanks! Smiley Wink
(2,107 Views)
Apparently the subject had already treated. See this post, in which the parsing of the database is the only workaround proposed
(2,071 Views)
