Exe with Application Builder
"Can Application Builder build *one executable* which consists of a constantly
running instrument VI and a VI which is periodically executed from a remote host
through the Labview HTTP Server. Both of which normally share data through a global variable VI".
(2,745 Views)
I believe so. What you will need to do is build just one application. The deal is that you cannot share data across different applications but different VIs within the same application is fine.
(2,745 Views)
