Executable Export Image - Picture Method - LV Crash - DAbort 0x786DE250 in drawmgr.cpp
I simplifed your VI to only load the same, display it and export to the Clipboard.
No crash after 102 iterations.
George Zou
Message 11 of 16
(1,666 Views)
I run your VI as is. No crash after 102 iterations.
George Zou
Message 12 of 16
(1,655 Views)
Are you running the executable or the VI?
Cheers
Message 13 of 16
(1,649 Views)
Yes. It crashes when build into exe.
This might be related to the known clipboard bug.
George Zou
Message 14 of 16
(1,639 Views)
Well, googling that, I get this thread which suggests a .NET workaround. I will give this a try as soon as I get a chance. Thanks!
Cheers
Message 15 of 16
(1,632 Views)
I marked this solution solved because the BMP mode did fix the crash. The issue with EMF mode is continued here.
Also, attached is a workaround supplied by NI using EMF format and .NET. This solution works, but is slow due to its need to write and read from file.
Cheers
Message 16 of 16
(1,586 Views)
