Executable - Missing subVIs on Build Computer
Hi there,
I've managed to generate an executable to run the LabVIEW VI.  However, an error message pops up saying that I'm missing 20-odd sub VIs.  I'm trying to run the .exe on the build computer (before I move elsewhere).
These sub VIs are all present in the Dependencies list.  Have I missed something?  Suggestions?
Cheers.
Message 1 of 16
(6,595 Views)
Are you calling the Sub VIs dynamically? How did you build the Exe file?
Message 2 of 16
(6,582 Views)
I do not know what it is to call a sub VI dynamically.
I used Application Builder to build the .exe.
Message 3 of 16
(6,580 Views)
The subVIs are called statically.
Message 4 of 16
(6,567 Views)
Did you install the full run time engine (not just the minimum or web brower plugin)? What version?
Can you tell us the names of some of the missing VIs? Are they your own or from vi.lib?
Message 5 of 16
(6,561 Views)
Are  you using the  Report Generaton Toolkit?
Message 6 of 16
(6,528 Views)
Did you built an installer or did you just move the executable?
If you just moved the executable, did you remember to keep the "data" folder next to it?
Message 7 of 16
(6,513 Views)
The LabVIEW Run Time Engine installed is 12.0.1 (I'm running LabVIEW 2012).  I don't know if it's the full time engine or not, this was installed before my time.  I've just tried to install "LabVIEW 2012 SP1 (32-bit) Run-Time Engine for Windows", but it said "cannot install" as a higher version is already installed.
The missing vi's are all related to mysql VI's from two libraries.  Included sql_open.vi, sql_close.vi, etc.
Yes, I'm using the Report Generation Toolkit.
I built just the executable, not an installer.  I've not tried to move the executable.  I'm trying to run the executable on the same machine that it's built on.
Message 8 of 16
(6,496 Views)
It looks like Labview Run-Time versions 8.2.1, 8.5.1, 8.6.1, 2009 SP1, 2009 SP1 (64-bit), 2010 SP1, 2010 SP1 (64-bit), 2011 SP1 f2 are also installed.  Is it a bit too much?
Message 9 of 16
(6,488 Views)
The Report Generation Toolkit actually dynamically loads in classes, so you have to force them to be in your executable.  You do this by adding the libraries from vi.lib to your project and then add them to the "always include" in the build spec of the executable.
I'm not sure about the mySQL as I have not used that library.
Message 10 of 16
(6,482 Views)
