Executable - User Event Generated to Stop SubVI (LV7.1)
I have a main VI that dynamically loads and runs a subVI at a certain point.  When the main program is stopped, I have a 'Stop' Case that generates a User Event to stop the running subVI window which is event-based.  In source code, works fine.  In executable, running subVI does not stop.  Any good reason for this and any good workarounds?
Sincerely,
Don
(3,132 Views)
ps. In general, anyone having problems with user events in executables built in LV7.1?  Working fine in source, getting crashes with some operations that generate user events in executables.
Sincerely,
Don
(3,121 Views)
hi there,
hm, as a first guess. where and when is the UserEvent unregistered and destroyed? do you wait for the SubVI to stopp before you unregister and destroy the UserEvent?
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(3,118 Views)
I believe I have solved my problem.  Somehow an error occurred in the subVI which held up execution so that the user event could not fire and close the subVI.  I am still investigating the cause of this but I have retested and it appears to work as expected now.  Additionally, my second problem occured as a result of an Abort VI I used if the application was an executable (and that is why it did NOT occur just using source code).
Sincerely,
Don
(3,108 Views)
