Executable VI with Labview 2011
Hi Patrick,
I hope there is no issue with the version. When I run the EXE on the machine where LabVIEW 2010 version installed, it runs without any issue. But when I transfered the EXE to the machine where LabVIEW 2010 RTE installed, I am facing the above issues.
Error describing.
Lab VIEW :Resource not found, An error occurred loading VI ‘NI_AAL Pro.lvlib:Real FFT.vi’.LabVIEW load error code : could not load front panel
For your information, this library is present in the dependencies in the project from where the EXE is developed. There is lock indication for this library.
Thanks and Regards
Giridhar
Message 11 of 11
(548 Views)
