Executable can not update VISA resources (UART)
Hello
An executable which I have prepared from a VI can not update the available VISA resource for a RS232 connection.
e.g. An UART to USB driver which I have connected to the PC is not available in the pull down menu of the VISA resources which I have implemented as control. There is no entry available.
Is there any special setup for the build process necessary
Regards
Joerg
(2,782 Views)
Does the machine have NI-VISA on it?  E.g. the NI-VISA runtime?
http://www.medicollector.com
(2,752 Views)
many thanks for the answer, it is exactly the problem. I have installed the windows driver for the usb2rs232 converter, but I forgot to install the VISA driver for the LabVIEW environment (VISA runtime).
Now it is working!
Regards
Joerg
(2,714 Views)
