Executable crashes Saving Excel Files on some PCs
Hello All,
I am trying to save Excel files after I have edited them.  But on some PC the executable works and some it does Not.  I made an installer and that too has issues.  I have attached  zip file of the issue I am having.  The debug works and the EXE work on the PC I built it on, but Not all client PC's the app is installed on work.
Info:
Labview 2018
all PC windows 10
Excel version : MS 365 version 2008 Build 13127.21668
Thank you for your time,
RS
(2,515 Views)
Hello, I'm not sure if it applies to your case, but maybe some of the client PCs doesn't have an active licence of MS Office and that breaks the code. You could search for that.
Roger Garcia, Certified LabVIEW Developer
HTML tutorial
There are two ways to tell somebody thanks: Kudos and Marked Solutions
(2,420 Views)
Hello Roger,
From what I have seen there is an active Excel application on all PC's and Excel is involved in many other tasks.  I saw there are different versions of Excel on the PC's so it seems if the version of Excel doesn't match the Client PC the App has a run time failure in trying to save the Excel files using this save VI (Save Report to File.vi).
In further exploring that MS office has kept the same version number 16 from the release in 2019 to now so it is difficult to tell these versions apart without using the build number. I wonder why there is a compatibility issue in saving?  Is there any other way to open, edit and save Excel files over these versions?  The change I am trying to make are Not complex just edits to numbers in given cells on a standard template.
Thank you for your help,
(2,374 Views)
You are right i didn't remember that, but since Office 365 release I also had compatibility issues, so saving this files only works for previous versions. The work around I could recommend is to save de files as CSV files, which are 100% Excel compatible (no matter the version) and you have more editing tools and capabilities with Labview Base software.
HTML tutorial
(2,368 Views)
Hello Roger,
I wish I could do that but then I loose the template and have to add a manual step to import the data back into the template.
It seem to work with which ever version of Excel is on the development machine; as I have tried with 2 machines with different versions of Excel.  So it looks like Labview has libraries compatible to both.  Is there away to check the version of Excel and select the library that is compatible with it, before making the calls to open the Excel file?
Thank you for help,
Raj
(2,354 Views)
