Executable file and MQTT
Good Morning,
I have implemented a Labview Routine which is including MQTT communication blocks ad I downloaded from github. The program is working but when I get the executable file it fails in getting the input signal from the MQTT communication. Anyone could give me an hint about what could be the source of the problem and any possible solution?
(1,285 Views)
Hi Giovanni,
So you have created a VI, which you don't attach.
You used some 3rd party VIs, which you don't provide a link for us.
You get errors and don't tell use their numbers/descriptions.
And now you want us to find/solve your problems and provide solutions?
Which kind of answers do you expect?
(1,271 Views)
At least with this e mail I get a guidance on how a request should be presented.
Thank you very much for your time and patience I will formulate better my doubt.
(1,258 Views)
