Executable hangs with ActiveX web browser
> I was able to reproduce your issue by taking Mike Porter's executable and using a LabVIEW Remote Front Panel as the webpage to access.
> This exe works great when accessing normal webpages (ni.com/yahoo.com etc...).
> The problem occurs when accessing a LV remote front panel.
> I saw the same errors you did.
> I will file a Corrective Action Request (CAR) on this issue.
> I then rebuilt the executable with remote debugging.
> I found something unique here.
> When I remotely debug the executable, it works!
> There is a bug though.
> When I remotely control the exe, the webpage gets published on the original executable shell and not the remotely controlling panel I have open!
> I will be filing a CAR on this as well.
I would like to follow the progress on these issues. Did you get CAR ID #s for these?
Message 21 of 22
(805 Views)
I made some changes which seem to provide a simple workaround. I'm not sure all changes were necessary. I moved the Invoke Node IWebBrowser2 out of event structure but it still failed. I changed the buttons' Mechanical Action to Latch When Release so eliminate the need for a feedback node. I also used event Value Change instead of Mouse Down. Solution attached.
Message 22 of 22
(801 Views)
