Executable program performing Error 267 occurred at System Exec.vi
Dear everyone,
I'm having issues trying to execute an external program inside a vi using System Exec.vi!
Platform: Windows 10, Labview2025, NI-XNET lib
What the .vi do:
I'm interfacing through CAN-bus using XNET with a device to retrieve MAC address. With that MAC I would like to generate a QRcode with an external python generated exe. The program cmd is the following:
cmd /c C:\Users\blablabla\SW_Collaudo_Inverter\qr_generator.exe --ssid EStorage_WiFi_629104 --encryption nopass --extra MACaddr:90b841629104
Both are working fine inside Windows CMD, wherever I launch them.
What I tried to solve the problem:
  • I added cmd \c before the executable prog
  • I tried to pass all the string  "cmd /c C:\Users\blablabla\SW_Collaudo_Inverter\qr_generator.exe --ssid EStorage_WiFi_629104 --encryption nopass --extra MACaddr:90b841629104" to the command line pin of the System Exec.vi without using the concatenate string.vi
  • I tried to pass options "--ssid EStorage_WiFi_629104 --encryption nopass --extra MACaddr:90b841629104" to the standard input pin of the System Exec.vi
  • I already read other topics regarding this issue but unfortunately, following all advices the problem still remain. I tried to send to the System Exec.vi the path of the external program in 2 different ways: 1) Absolute path
gcambie88_0-1758639838948.pnggcambie88_0-1758639838948.png        2) using the build path.vi
Anyway I'm attaching the vi.
Any help or suggestion will be really appreciated!
Cheers
Message 1 of 1
(771 Views)
