Executable version (7.1.1) does't match resource file (7.1)
Hello
I try to run an (old) executable control program from Keithley and I get this error message.
"Executable version (7.1.1) does't match resource file (7.1)"
I have Labview 8.5 installed and I try to control a Keithley S46 switch system.
Is someone can help?
Thank you
(2,799 Views)
Ah, the wonders of searching...
Executable Version (7.1.1) Doesn't Match Resource File (7.1) [article no longer available]
(2,795 Views)
Thank you for your help.  Before posting,  I did try to install the resource file 7.1.1 but refuse to install because I have a higher version.
I am willing to try other wonders!
(2,784 Views)
What do you mean by you tried to "install the resource file 7.1.1". What does that mean? Do you mean you tried to run the LabVIEW 7.1.1 RunTime Installer?
(2,780 Views)
