Executable version doesn´t match resource file (7.1). Check your configuration
Hi everyone !!!
Yesterday I needed to install an application developed in LabVIEW 7.1 but before the installation process ended  a crash ocurred, thus ending it, showing me the following message Executable version doesn´t match resource file (7.1). Check your configuration. My problems were just beginning ... after that, every time I tried to run NI MAX it doesn´t start and the message is showed again. Sometimes I think LabVIEW is a hive of bugs ....
To help you people out there who want to give me a hand, I think I need to say that  the following programs are installed in my machine :
LabVIEW 7.1 Professional
LabVIEW 8.0 Professional
LabVIEW 8.2 Evaluation
NI MAX 4.1
Thanks in advance to you guys who will  help me !!!!
(4,673 Views)
I just liked to say that the message that appears is  Executable version (7.1.1) doesn´t match resource file (7.1). Check your configuration
(4,670 Views)
Hi Giovani,
Sorry for the extremely late reply, but I found this link while searching for a solution for another Discussion Forum
Uninstaller Error when trying to change National Instruments software
Here is the solution for your problem (which I hope still doesn't exist):
Executable Version (7.1.1) Doesn't Match Resource File (7.1)
Michael K. | Applications Engineer | National Instruments
| Michael K | Project Manager | LabVIEW R&D | National Instruments |
(4,614 Views)
