Executable version shows errors not seen in development
I have a vi that contains the VISA Configure Serial Port vi. I've been developing the vi in which this resides for some time with no problem. When I create and run an executable file (.exe) on my own pc, I get error code 1073807246, "resource is valid but VISA cannot currently access it." What does this mean? I did not create an "installation". Is this necessary?
(2,937 Views)
Message mean that another process has control of the COM port.  Does your vi "close" the port after you are done using it?  Did you shutdown LV environment before running your .exe?
(2,926 Views)
That was exactly my problem. I didn't completely shut down Labview. Thank you very much.
(2,912 Views)
