Executable with NET reference broken on XP SP3 target.
Greetings,
I'm having trouble getting a NET reference to resolve on an XP SP3 platform. Installing the NET Framework 2.0 and NET Framework 3.5 redistributables, didn't cure the problem.
Can it be tricky to get NET objects registered?
Are there any LabVIEW compiler-switches. "Remove Unused Polymorphic" is selected (default)
The attached VI is compiled but the EXE opens broken.
...and, in the interest of full disclosure,  It's a "fresh" XP SP3 installation running as a "Virtual Machine" under VMWare.
Thanks/Cheers!
(2,674 Views)
... Please ignore this question!
Working now after installing Net Framework 3.5
Apparently I was installing wrong type of component (not really sure...)
(2,665 Views)
