Executable won't run
I have a program that runs fine under the development system, but the executable won't run on the same computer, much less a target computer.
It appears to stop in the initialization section. The log file is not created and the Excel data does not appear to be read. I have verified that the Files folder is there and the Excel file is in it.
I enabled debugging, but that did not help. The only front panel button that works is the Stop button.
(4,196 Views)
Put a path indicator on one of your paths and rebuild the application. You will find that the path in the executable is not what you think it is.
(4,185 Views)
(4,178 Views)
You are right. The “Current Path” is based on the location of the development VI, not the executable program.
I changed it to a fixed path and it works. Thanks for the help.
(4,148 Views)
I would strongly recommend to use the suggestions in my link above. A "fixed path" is fragile, because the VI will break as soon as the exe is moved elsewhere or even if somebody installs on a different drive letter.
(4,143 Views)
I agree with altenbach. A fixed path is not the right solution. Take a look at the link that altenbach provided.
(4,141 Views)
