Executables
hello,
I'm trying to create an executable of my project. I have two .vi one at FPGA and other at target, I communicate them with FPGA interface fuctions.
I want to know how to create an executable, because I can't select tools>>build .exe
Is not possible to create executable located in sbrio? because I can build executable when the .vi is in computer (host)
Message 1 of 9
(5,373 Views)
Working with RT devices, an executable is always automatically created and transferred to the RT target when you deploy the application.
What else you would like to do with the executable file?
Paolo
LV 7.1, 2011, 2017, 2019, 2021
Message 2 of 9
(5,356 Views)
Where is this executable?
I only want to do an executable for running it in computers that they haven't installed labview
Message 3 of 9
(5,351 Views)
I thought you were referring to the executable file to be run on the sbRIO, didn't you?
That file would be useful only on other identical sbRIO devices with all NI stuff installed.
Paolo
Message 4 of 9
(5,342 Views)
Can't I create an application .exe in sbrio? Only do  i this in .vi that they are in computer and not in the target?
Message 5 of 9
(5,339 Views)
sbRIOs do not run Windows.  So it makes no sense to create executables to run that code on any PC.  You build the application for the sbRIO and deploy it to that sbRIO.  The application is built specifically for that target.
Now if you made an application to talk to that sbRIO that runs on a PC, you can build an exe for that and deploy it to any PC you want.
Message 6 of 9
(5,319 Views)
Ok, then, I should do a .vi that it will be communicate with target with tcp for example, and then I could create my .exe?
Message 7 of 9
(5,312 Views)
That is exactly what I do.  Personally, I like to use the STM library since it takes care of much of the communications protocol for me.
Message 8 of 9
(5,307 Views)
Thanks so much, I'll try to do it like that.
Message 9 of 9
(5,305 Views)
