Execute Event structure only on first value change
Accepted by topic author yp21
  • Do the comparison before the case structure, eliminating the lower shift register.
  • If you swap the cases, you don't need to invert the OR operation.
  • You still have that 28.5714ms wait constant. waits are integers.
  • Your outer loop has an infinite loop rate, consuming 100% CPU in the FALSE case
  • Code still looks clumsy. Use a state machine and eliminate the inner loop.
Message 11 of 12
(955 Views)
Your state machine suggestion was perfect. It does exactly what I want now. Thank you all for your suggestions and ideas. I definitely feel more confident with doing things like this.
Message 12 of 12
(942 Views)
