Execute Labview code compiled under XP Pro with Windows 7 ?
Hi. As the title says, I'm making LabView EXE test software under XP Pro SP3. Any issue directly running that software on a machine running Windows 7 ? Or do I need to install LabView on the Win7 machine and recompile from there? Thanks in advance, and best regards, François
(3,160 Views)
Accepted by topic author BenQc
No need to install LabVIEW to have your application run on the target PC with Windows 7.
But: You must install the Runtime Engine for this version of LabVIEW on the target PC.
Regards, Guenter
(3,153 Views)
Thanks much!  :manhappy:
(3,150 Views)
