Execute Straigh-Line Move Function block "all the time"
I am using the Softmotion module to control my Solidworks Assembly in Labview. I am using the vitrual motors that are connect on the resource on the Straight-Line Move block. I want to execute the block "all the time" so my Solidworks simulation will always update. Anyone got an quick easy tip on how this is possible?
Thank you!
(3,051 Views)
Hi Claponio,
I believe that what you are looking for is an invoke node with the method 'start', which can be connected to your Straight-Line Move Function block. The movement will continue until the VI is stopped or a 'stop' invoke node is executed. There is an inbuilt example that does what you need, see Help>Find Examples > Straight Line Move.lvproj
Let me know if this helps!
Leah
(2,972 Views)
