Execute case structure after every 10secs time lapse increment
In the VI code attached, how to execute the case structure after every 10secs time lapse.  In the example given below, I would like to access the "True" case 6 times (60 secs/10).
Or if there is an alternate way to access the case structure once every 10 secs?
Thanks!
(1,660 Views)
Hi hiNI,
Which of those 3 case structures in your image do you want to execute with a 10s interval?
Generic adivce:
  • As the While loop should iterate each 100ms you could call the case structure each 100th iteration…
  • Use ElapsedTime (set to 10s) to give you a boolean signal to execute your case structure…
(1,649 Views)
The case structure, "Take data" should be where the time lapse data should execute.
For you first suggestion, do I need then to add a "count" input to increment up to 100 each time?
Thanks.
(1,646 Views)
Hi hiNI,
You already use some sort of ElapsedTime function, so you should use it correctly:
Why is the TimeTarget set to "1" when you want to execute the case after 10s?
Well, yes.
(1,635 Views)
Hello GerdW,
In the "Take Data" case, I wait for 1 minute in that case before going to another state.  I should have labeled that state "Wait". However, in the "Wait" case, I wanted to just enter into that enclosed case every 10 secs (in reality, to capture a reading from an instrument).
With this in mind, I do not think I can get your solution to work.
I accept all responsibility of not clarifying explicitly the requirements.  My sincerest apologies!
Thanks!
(1,584 Views)
