Execute delay only once the entire time
Are you referring to the one in the black circle?
Message 11 of 14
(545 Views)
No, none of those. See the image I attached above.
Message 12 of 14
(542 Views)
great,the code seems working now but now im faced with a problem. If the delay time is longer than the time the boolean is activated, the code will not delay. im trying to figure out a code at the moment a true boolean is detected, no matter how short it is at the true state(0.1sec), it will call the 1sec delay
Message 13 of 14
(530 Views)
Please attach your new code. Currently you have a 5000ms delay in the main loop (why???), meaning that this is you polling inteval. That seems way too long. You probably should use an event structure.
Message 14 of 14
(516 Views)
