Execute subVI - specific time
Hello folks!
I have a generic application which execute a timed loop sequence. Inside loop, I tried to generate a random number and get the curent time/date when the number was generated.As you can see,
E.g :I set the period to 50 ms.In ElapseTime indicator , the difference between two successive elements varies between 47ms and 62 ms. My intention is to obtain 50 for this diferrrence.
(3,084 Views)
I get exactly 50ms increments if I set it to 50ms. What is your OS?
(3,080 Views)
I also get those 47 to 62ms variations when setting a delay of 50ms (WinXP). That is due to limitations of the OS: before Win7 (or WinVista?) the resolution of GetDateTime is ~16ms, whereas Win7 offers a resolution of 1ms.
So the problem is not the exact timing of the TimedLoop but the limitations of measuring time on Windows OS...
(3,078 Views)
The OS is WinXP.
Is there a way to "cheat" that?
Thanks for your replies!
(3,073 Views)
Accepted by topic author Samoth
Hi Samoth,
no need to cheat. Just use the "Global Endtime" output of the TimedWhileLoop...
(3,071 Views)
