Experience with Burkert Mass Flow Controlers ?
I have to control a Burkert MFC (model 8713) with LabVIEW. Since these are fairly popular devices, may somebody could have some ready-to-use vis to share ?
Thanks !
Chilly Charly    (aka CC)
Message 1 of 9
(5,179 Views)
Bump !
Any hint ? Something about RS485 communication and networking ? Please ! Otherwise
Message 2 of 9
(5,144 Views)
I dont know how far this link would be relevant to you.
http://www.lammertbies.nl/comm/info/RS-485.html
Hope it helps.
Message 3 of 9
(5,125 Views)
Thanks ! That give me already some answers to my bag of questions.
May be you have one very important answer, before I read thoroughtly all the doc : can I use an RS232 or RS422 com port in connection vith an RS485 device ? What are the caveats ?
Message 4 of 9
(5,120 Views)
Well I guess you can. I have personally never used 485. Only thing that i can think of may be that there must be some protection against contention. otherwise standard connections would work unless something is specified for the equipment using it.
http://www.educypedia.be/computer/rs232485bis.htm
This is kind of compiled links here for 232-485. may be this would give you some help. There is an app note in it that will give you some of the answers.also find there a TI note just above that app note. That is a very well compiled info.
Hope it helps.
Ravi
Message 5 of 9
(5,106 Views)
To make communications easier with RS485 to labview, I would suggest using a USB to RS485 converter.  I've used this converter before and its pretty easy to setup.  B&B electronics http://www.bb-elec.com/product_family.asp?FamilyId=357
In the meantime, once you get your USB/RS485 converter you can talk to the MFC using Burkert's communication tool http://www.burkert.com/COM/buerkert_products_new.php?type=8711  (its near the bottom of the page).
Message 6 of 9
(5,104 Views)
Iiiike !! LabVIEW vi's
jkho
Message 7 of 9
(5,098 Views)
Dravi99 and jkho
Guys, my problems are solved. You have really been of much help. Thanks a lot !
Message 8 of 9
(5,093 Views)
2007 -> 2017 : Smiley LOL Did you find the labview VI for Burkert Mass flow?
Message 9 of 9
(4,141 Views)
