Experience with Exar 17V358 chipset (PCIe to 8 X RS232)?
I am looking for a 8 port RS232 solution for a desktop PC. Anyone used LabVIEW with the following product? http://www.delock.com/produkte/G_89336/merkmale.html
Its doc says it has a "Exar 17V358" chipset, I wonder if this is a reliable model? I remember some forum posts saying usually the "FTDI" chipset is a safe choice, but those are the USB-to-RS232 adapters. I guess this PCIe adapter should be a safer choice compared to USB adaptors? I will need to control several external devices (MKS PR4000B units) and read values from some vacuum sensors.
(3,479 Views)
Hmm, it looks like the Delock one does not (officially) support Win10, so I will try another product, either two cards with 4 ports each, or a 8 port version:
https://www.startech.com/eu/Cards-Adapters/Serial-Cards-Adapters/4-Port-Native-PCI-Express-RS232-Ser...
(3,456 Views)
I haven't used these specific PCI cards myself (we usually used the external network to RS-232 servers from Moxa for large amounts of serial ports) but have good experiences with the Moxa products.
http://www.moxa.com/product/Multiport_Serial_Boards.htm
Rolf Kalbermatter  My Blog
(3,413 Views)
Thanks for the link! Actually I am still searching, because I try to find a product with good price /port numbers ratio, but also which has proper Windows 10 driver support (for another reason, I cannot use Win7 unfortunately 😞 ).
edit: this Moxa website also only states drivers up to Win7...maybe I can contact them whether these products work under Win10?
(3,409 Views)
