Experience with parameter analyser HP
Who has some experience with a HP paramter analyse, linked with a PC
trough Labview ?
I need to set up an interface between an HP4145A and PC trough GPIB
interface.
Does anybody has some tips, sample code, additional information,...??
Thanks in advance !!
Kristof
Belgium
(2,921 Views)
Look on the NI site: http://www.ni.com - Downloads - Instrument Driver
Network - Downloads, etc.
Direct address:
http://zone.ni.com/idnet97.nsf/9b2b33e1993d877786256436006ec498/8b48a562db25
5488862568ab005fb9a2?OpenDocument
There are two examples in the set.
Mikhail
(2,921 Views)
I already downed the HP4145B driver, but I can send with this driver command,
but I can't read a thing from the analyser.
> Direct address:
> Regards,
> Mikhail
(2,921 Views)
I remember that this type of HP products works just with one of the two NI
programming sets (I used NI DLLs with Visual Basic - not LV). If you use
functions (NI488) try to use subs (NI488.2) or vice versa.
"Kristof Poppe" wrote in message
news:3A96242C.2ECC9B07@sipex.be...
command,
> > Direct address:
> > Regards,
> > Mikhail
(2,921 Views)
