Expired Labview Eval Before Date
(3,474 Views)
Click to Date/Time Properties in Taskbar and change Date back (few days).
(3,474 Views)
Actually, I don't think setting the clock back will do it. I think the LabVIEW developers put in several measures to assure that once the software expired, it stayed that way. Its a little curious that it expired early unless you were messing around with your system clock, but I don't think there is much you can do about it. If you have another computer, just install the eval version there.
(3,474 Views)
In my computer this work.
(3,474 Views)
The LabVIEW 6.0 eval? I thought they designed it better than that.
(3,474 Views)
you may try to install a lower version of labview(5.0) and run it, then the Labview 6i eval can work again.
(3,474 Views)
