Expired license-Labview
When I launch LabVIEW 8.6 I notice that the License has expired. This is actually NOT the case. I need to make changes to a Customer Application and I cannot open LabVIEW. This is quite an emergency for me. How can I fix this?
(3,690 Views)
Maybe you can try activating it by using the NI License Manager?
Hope this helps
Now Using LabVIEW 2019SP1 and TestStand 2019
(3,686 Views)
Hi Ciphertech,
GovBob is correct.  Go into License Manger and try to activate LabVIEW.  If this does not work let us know what error it gives you when you try.
Adam H
(3,647 Views)
